Introduzione
The fan in the Epson VS250 projector helps prevent the projector from overheating. The projector has multiple components that produce heat and the fan helps cool these components down. This reduces the chance that the projector catches fire when dust particles enter. This guide will show you how to replace the fan. Before continuing with this guide, check the Air Filter guide, which is a more common cause of overheating and easier to fix. The Fan replacement guide requires more time and has a higher difficulty. This guide will require you to remove many screws when disassembling the project, and will require careful dismantling and untangling of circuitry within the projector.
Cosa ti serve
Place the projector on a flat surface.
Orient the projector so that the the word "Epson" is facing you.
Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
