Salta al contenuto principale
Epson Stylus Photo 820 Top Cover Replacement
Cosa ti serve
  1. Epson Stylus Photo 820 Top Cover Replacement, Top Cover: passo 1, immagine 1 di 2 Epson Stylus Photo 820 Top Cover Replacement, Top Cover: passo 1, immagine 2 di 2
    • To remove the top cover of the printer, you have to first release it from several tabs.
    • This may take more than one person to complete.
    • These three are the easiest tabs to remove. They are located on the back side of the printer.
  2. Epson Stylus Photo 820 Top Cover Replacement: passo 2, immagine 1 di 2 Epson Stylus Photo 820 Top Cover Replacement: passo 2, immagine 2 di 2
    • Push the tab in with one of the plastic opening tools.
    • Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
    • Repeat this process with the furthermost right tab, then proceed with the middle tab.
  3. Epson Stylus Photo 820 Top Cover Replacement: passo 3, immagine 1 di 3 Epson Stylus Photo 820 Top Cover Replacement: passo 3, immagine 2 di 3 Epson Stylus Photo 820 Top Cover Replacement: passo 3, immagine 3 di 3
    • It is recommended that Steps 3 and 4 be completed simultaneously. The tabs are identical, just on opposite sides.
    • Insert the pointed end of a spudger into the hole on the bottom left corner of the printer and pry out the tab.
    • This tab is the easiest to break, so be very careful.
  4. Epson Stylus Photo 820 Top Cover Replacement: passo 4, immagine 1 di 2 Epson Stylus Photo 820 Top Cover Replacement: passo 4, immagine 2 di 2
    • Insert the pointed end of a spudger into the hole on the bottom right corner of the printer and pry out the tab.
  5. Epson Stylus Photo 820 Top Cover Replacement: passo 5, immagine 1 di 3 Epson Stylus Photo 820 Top Cover Replacement: passo 5, immagine 2 di 3 Epson Stylus Photo 820 Top Cover Replacement: passo 5, immagine 3 di 3
    • The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
    • The release points for the tabs are located in holes on the depressed area of the base (darker piece).
    • Use the pointed end of a spudger to pry out the tab.
    • Use one of the plastic tools to keep the tab pried out. Once it releases, push in towards the printer (viewing from the side) and pull up on the case.
  6. Epson Stylus Photo 820 Top Cover Replacement: passo 6, immagine 1 di 1
    • All of the tabs have now been released.
    • When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
    • Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
  7. Epson Stylus Photo 820 Top Cover Replacement: passo 7, immagine 1 di 2 Epson Stylus Photo 820 Top Cover Replacement: passo 7, immagine 2 di 2
    • Pull the cover up and off.
Conclusione
Cal Poly, Team 20-68, Walters Spring 2011 Membro di Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,303
