Salta al contenuto principale
Introduzione
Replacing your ink cartridges.
  1. When you are low on ink your green power light will be flashing and your error light will stay a solid red.
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Lift the printer window open by pulling up on the tab. Your printer should now be in the same state as shown in the second picture.
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture) Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Press the tabs with the upward facing arrows to open the hatches as shown in the first picture. Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right. Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Insert your new ink cartridges and close the hatches. Close your printer door and push the ink cartridge button on the far right and again. After your ink charges you're ready to print!
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
Linea Traguardo
Alex Lin
Membro da: 10/04/2011
99 Reputazione
3 Guide realizzate
Cal Poly, Team 20-68, Walters Spring 2011 Membro di Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Membri
6 Guide realizzate
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,595
