Salta al contenuto principale
Epson Stylus Photo 1400 Ink cartridge replacement
Cosa ti serve
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: passo 1, immagine 1 di 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: passo 1, immagine 2 di 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: passo 2, immagine 1 di 2 Epson Stylus Photo 1400 Ink cartridge replacement: passo 2, immagine 2 di 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: passo 3, immagine 1 di 2 Epson Stylus Photo 1400 Ink cartridge replacement: passo 3, immagine 2 di 2
    • Close cartridge cover.
    • Close cover of the printer.
Conclusione
Altre 2 persone hanno completato questa guida.
Larry Huang
Membro da: 10/12/11
1.004 Reputazione
4 Guide realizzate
Cal Poly, Team 17-11, Regan Fall 2011 Membro di Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Membri
12 Guide realizzate
6 Commenti
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Replica
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Replica
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Replica
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Replica
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 49
Tutti i Tempi: 10,332
