Salta al contenuto principale
Epson Stylus NX240 Side Buttons Replacement
Cosa ti serve
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: passo 1, immagine 1 di 2 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: passo 1, immagine 2 di 2
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: passo 2, immagine 1 di 1
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: passo 4, immagine 1 di 1
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: passo 5, immagine 1 di 1
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: passo 6, immagine 1 di 1
    • All parts should be separate now to clean or replace.
Conclusione
Joshua Fabel
Membro da: 10/13/16
104 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 28
Tutti i Tempi: 648
