Salta al contenuto principale
Epson Stylus NX230 Front Button Replacement
Cosa ti serve
  1. Epson Stylus NX230 Front Button Replacement, Front Buttons: passo 1, immagine 1 di 1
    • Before beginning, make sure the printer is unplugged and turned off to avoid electric shock.
    • Lift the top of the printer to see the inside.
  2. Epson Stylus NX230 Front Button Replacement: passo 2, immagine 1 di 3 Epson Stylus NX230 Front Button Replacement: passo 2, immagine 2 di 3 Epson Stylus NX230 Front Button Replacement: passo 2, immagine 3 di 3
    • Locate the control panel, the part of the printer with the buttons on it.
    • Push the control panel away from the outside of the printer, taking the panel out of the holes that hold it in place.
    • Repeat the above step for the other side of the control panel.
  3. Epson Stylus NX230 Front Button Replacement: passo 3, immagine 1 di 2 Epson Stylus NX230 Front Button Replacement: passo 3, immagine 2 di 2
    • The front control panel is attached to the printer on both sides by a grey piece of plastic that runs on a track. Remove the control panel from the track by pushing it away from the track on both sides.
    • The ribbon cable on the left side of the control panel, also known as the ribbon cable, must stay attached to the printer. If the cable becomes detached the front buttons will not be responsive.
  4. Epson Stylus NX230 Front Button Replacement: passo 4, immagine 1 di 1
    • Flip the detached control panel over so that the buttons are facing down.
    • Remove the two 3mm Phillips #2 screws from the back of the control panel.
  5. Epson Stylus NX230 Front Button Replacement: passo 5, immagine 1 di 1
    • Lift up the gray plastic piece.
    • Remove the 3mm Phillips #2 screw.
  6. Epson Stylus NX230 Front Button Replacement: passo 6, immagine 1 di 1
    • Split the control panel in half by gently pulling on both sides of the seam that runs through the control panel.
  7. Epson Stylus NX230 Front Button Replacement: passo 7, immagine 1 di 2 Epson Stylus NX230 Front Button Replacement: passo 7, immagine 2 di 2
    • Separate the two pieces to reveal the green circuit board.
    • Be sure to not detach the circuit board from the white tap.
    • Remove the green circuit board by lifting it up gently with your hands.
  8. Epson Stylus NX230 Front Button Replacement: passo 8, immagine 1 di 1
    • Remove the buttons with the plastic opening tool by pressing the front panel down and lifting the buttons up.
Conclusione
To reassemble your device, follow these instructions in the reverse order.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 6-1, Forte Spring 2014 Membro di Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
4 Membri
10 Guide realizzate
1Commento della guida
Wow! this guide is clear and concise. wahoo!!!
kyle price - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 958
