Salta al contenuto principale
Epson Powerlite S5 Projection Lamp Replacement
Cosa ti serve
  1. Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: passo 1, immagine 1 di 2 Epson Powerlite S5 Projection Lamp Replacement, Projection Lamp: passo 1, immagine 2 di 2
    • Make sure the power is off before beginning.
    • Unplug the projector's power cord from the wall.
    • Allow the projection lamp to cool completely before replacing.
  2. Epson Powerlite S5 Projection Lamp Replacement: passo 2, immagine 1 di 2 Epson Powerlite S5 Projection Lamp Replacement: passo 2, immagine 2 di 2
    • Using a Phillip's head screwdriver, remove the screw from the back.
  3. Epson Powerlite S5 Projection Lamp Replacement: passo 3, immagine 1 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 3, immagine 2 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 3, immagine 3 di 3
    • Slide the cover back.
    • Lift cover to remove.
  4. Epson Powerlite S5 Projection Lamp Replacement: passo 4, immagine 1 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 4, immagine 2 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 4, immagine 3 di 3
    • Locate the two screws on either side of the projection lamp.
    • Using a Phillip's head screwdriver, loosen the two screws.
    • The screws only loosen. You don't have to worry about them falling out.
  5. Epson Powerlite S5 Projection Lamp Replacement: passo 5, immagine 1 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 5, immagine 2 di 3 Epson Powerlite S5 Projection Lamp Replacement: passo 5, immagine 3 di 3
    • Grip the two plastic bars on the top of the old projection lamp.
    • Remove the projection lamp by pulling straight up.
    • If there is any lamp breakage, handle the shards carefully to avoid injury.
Conclusione
Greg Brown
Membro da: 10/06/16
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,230
