Salta al contenuto principale
Epson PowerLite Home Cinema 1040 Lamp Replacement
Cosa ti serve
  1. Epson PowerLite Home Cinema 1040 Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 2, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 3, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 3, immagine 2 di 2
    • Slide the lamp cover off by sliding out, then up.
  4. Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 4, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 4, immagine 2 di 2
    • Loosen the 7mm dark gray screws keeping the lamp in place.
    • The screws do not need to be removed. Simply loosening the screws will allow the lamp to slide out.
  5. Epson PowerLite Home Cinema 1040 Lamp Replacement: passo 5, immagine 1 di 1
    • Grip the lamp by its raised section, and carefully pull the lamp out of the projector to remove it.
    • The lamps contain mercury; consult state laws regarding disposal.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 259
