Salta al contenuto principale
Epson PowerLite Home Cinema 1040 Cooling Fan Replacement
Cosa ti serve
  1. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Removing Housing: passo 1, immagine 1 di 1
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 2, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 2, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Use the Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • Slide off the lamp cover and remove it from the projector.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 3, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 3, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 3, immagine 3 di 3
    • Use the Phillips #1 (PH1) screwdriver to remove the three 7 mm screws around the perimeter of the lens cover.
  4. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 4, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 4, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Remove the air filter cover.
    • Remove the two PH1 7mm screws from under the air filter cover.
  5. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 5, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 5, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Remove the two black, PH1, 6mm screws.
  6. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 6, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 6, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 6, immagine 3 di 3
    • Flip the projector so the bottom is exposed.
    • Remove seven PH1 7mm screws on the outer rim of the projector.
    • Some screws are located deeper in the housing and a bit extension or longer screwdriver may be required.
  7. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 7, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Continuing on the bottom, remove the two black, PH1, 6mm screws.
  8. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 8, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 8, immagine 2 di 2
    • Remove the cover on the backside of the projector where the inputs are located.
  9. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 9, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 9, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 9, immagine 3 di 3
    • Pull the top half of the housing upwards and rest it on the side.
    • Be careful to not pull upwards too hard. The top is still connected by a thin electric strip.
  10. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 10, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 10, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 10, immagine 3 di 3
    • Using your fingernail or another thin wedging tool, disconnect the electronic strip from the motherboard.
    • Remove the top half of the projector housing completely and set it to the side.
  11. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: passo 11, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: passo 11, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement, Cooling Fan: passo 11, immagine 3 di 3
    • Use the Phillips #1 to remove the 3 silver 7 mm screws that secure the fan frame.
  12. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 12, immagine 1 di 2 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 12, immagine 2 di 2
    • Remove the fan frame.
  13. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 13, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 13, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 13, immagine 3 di 3
    • Use a Phillips #1 to remove the bottom left 7mm silver screw.
    • Remove the fan from inside the fan housing.
    • The fan will still be connected to the projector with the wires. We will remove those in the next step.
  14. Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 14, immagine 1 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 14, immagine 2 di 3 Epson PowerLite Home Cinema 1040 Cooling Fan Replacement: passo 14, immagine 3 di 3
    • Unhook the fan wires that connect to the motherboard.
    • Separate the fan wiring from the projector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 295
