Salta al contenuto principale
Epson PowerLite Home Cinema 1040 Air Filter Replacement
  1. Epson PowerLite Home Cinema 1040 Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Turn off the projector and unplug the power cord.
  2. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 2, immagine 1 di 1
    • Locate the air filter cover located on the top of the projector on the nearest side adjacent to the lens
    • Remove the air filter cover by gripping the ridge underneath it and pulling upwards
  3. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 3, immagine 1 di 1
    • Pull the air filter out of the projector by gripping the black tab on the top of the air filter
    • The air filter contains ABS resin and polyurethane foam; dispose according to local regulations
  4. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 4, immagine 1 di 1
    • Push the new air filter gently into place until there is a click
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 100
