Introduzione
If you need to replace your Epson PowerLite 83+ projector's power supply, you can remove it using this guide. A faulty power supply may cause the projector to not show any status lights when attempting to power on the device.
Prior to beginning this repair, be sure to power off the projector and unplug it from the power adapter.
Cosa ti serve
Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
Lift the motherboard from the front side of the projector to clear the ribbon cables.
Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
Remove the motherboard from the case.
Remove the four 6 mm Phillips #2 screws securing the fan bracket.
Remove the fan bracket by pulling straight up and set it aside.
