Salta al contenuto principale
Epson PPC650 Camera Case Replacement
Cosa ti serve
  1. Epson PPC650 Camera Case Replacement, Case: passo 1, immagine 1 di 3 Epson PPC650 Camera Case Replacement, Case: passo 1, immagine 2 di 3 Epson PPC650 Camera Case Replacement, Case: passo 1, immagine 3 di 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Camera Case Replacement: passo 2, immagine 1 di 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Camera Case Replacement: passo 3, immagine 1 di 2 Epson PPC650 Camera Case Replacement: passo 3, immagine 2 di 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Camera Case Replacement: passo 4, immagine 1 di 1
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Camera Case Replacement: passo 5, immagine 1 di 3 Epson PPC650 Camera Case Replacement: passo 5, immagine 2 di 3 Epson PPC650 Camera Case Replacement: passo 5, immagine 3 di 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
Conclusione
Brittany
Membro da: 02/12/13
101 Reputazione
1 Guida realizzata
Ohio State, Team 1-5, Buehl Spring 2013 Membro di Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 153
