Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Make sure the camera is turned off here. Remove batteries from the battery compartment located on the bottom of the camera Remove SD card for the card reader compartment located on the flat side (left side)  of the camera
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Remove 2 screws on the rounded side of the camera wisdom here.
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Remove 3 screws on the flat side of the camera All silver screws go into the side of the camera that is silver
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Remove 4 screws from the bottom of the camera
    • Remove 4 screws from the bottom of the camera
  5. Separate the front and back pieces of the cameras plastic casing using a spudgerm here. WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control Use minimal force so that the plastic casing does not break
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Remove copper sheet from the front paneling and back. You will need to use a spudger to unsolder the copper paneling Use the spudger to separate the back circuit board from the camera
    • Remove copper sheet from the front paneling and back.
    • You will need to use a spudger to unsolder the copper paneling
    • Use the spudger to separate the back circuit board from the camera
  7. The picture viewing screen is glued to the backing as well as wired in with pink and white wires. Exert minimal force required to pull the screen loose from the camera
    • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
    • Exert minimal force required to pull the screen loose from the camera
    • Remove the pink and white wiring from the internal paneling. These wires are soldered in
    • Remove the orange data hookup cable which feeds into the back circuit board
    • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
    • Insert data hookup into the back of the camera and into the new screen
    • Re-solder the new pink and white wire onto the internal circuit board
Conclusione
Anne
Membro da: 12/02/2013
101 Reputazione
1 Guida realizzata
Ohio State, Team 1-5, Buehl Spring 2013 Membro di Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 214
