Introduzione
A replacement of the power supply unit is needed if the projector shows no sign of power despite the use of a functional power cable. It is located within the Epson Home Cinema 2150 almost at middle right next to the projector lens. It's a heavy black box.
The power supply is designed to deliver the proper power to the projector.
Cosa ti serve
Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
Unscrew the single 6mm Phillips#2 holding screw from the access panel.
Slide the panel horizontally, then lift up to remove the access panel.
Remove the air filter cover. Grip the piece with two fingers above and below at the center.
Grab the air filter from the protruding tab and pull the filter out.
Pull up on the rear panel retaining clip.
Pull the rear panel away from the device to remove.
Remove two 6 mm Phillips #1 screws.
Remove two 5 mm Phillips #1 screws.
The power supply unit is a black box. Inside, there are two connected circuit boards, each with a single connector.
Using needle nose pliers, disconnect the first white connection cable from the circuit board.
