Salta al contenuto principale
Epson Home Cinema 2150 Projector Lamp Replacement
Cosa ti serve
  1. Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: passo 1, immagine 1 di 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: passo 1, immagine 2 di 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: passo 1, immagine 3 di 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Projector Lamp Replacement: passo 2, immagine 1 di 3 Epson Home Cinema 2150 Projector Lamp Replacement: passo 2, immagine 2 di 3 Epson Home Cinema 2150 Projector Lamp Replacement: passo 2, immagine 3 di 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Projector Lamp Replacement: passo 3, immagine 1 di 3 Epson Home Cinema 2150 Projector Lamp Replacement: passo 3, immagine 2 di 3 Epson Home Cinema 2150 Projector Lamp Replacement: passo 3, immagine 3 di 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
Conclusione
Luis Garcia
Membro da: 09/26/22
577 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 721
