Salta al contenuto principale
Epson BrightLink 450wi Power Cord Replacement
Cosa ti serve
  1. Epson BrightLink 450wi Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • Flip projector upside-down.
    • The panel cover for the power source is on the projector's left side when upside-down.
  2. Epson BrightLink 450wi Power Cord Replacement: passo 2, immagine 1 di 2 Epson BrightLink 450wi Power Cord Replacement: passo 2, immagine 2 di 2
    • Begin unscrewing the two 11 mm screws that are attached to this cover plate. These screws will come loose and can be removed and placed in a safe location.
  3. Epson BrightLink 450wi Power Cord Replacement: passo 3, immagine 1 di 3 Epson BrightLink 450wi Power Cord Replacement: passo 3, immagine 2 di 3 Epson BrightLink 450wi Power Cord Replacement: passo 3, immagine 3 di 3
    • Once the screws are removed begin pulling the cover plate off gently.
    • It will come off in one smooth motion by pulling away towards the left of the projector.
  4. Epson BrightLink 450wi Power Cord Replacement: passo 4, immagine 1 di 3 Epson BrightLink 450wi Power Cord Replacement: passo 4, immagine 2 di 3 Epson BrightLink 450wi Power Cord Replacement: passo 4, immagine 3 di 3
    • Once the cover plate is removed, lift up the device and you will be able to see the plug for the power source.
    • To plug in, ensure the prongs on the plug are facing the right way to slot into the device power source port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
