Salta al contenuto principale
Epson BrightLink 450Wi Air Filter Replacement
  1. Epson BrightLink 450Wi Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Rotate the projector on its side with the Wi-Fi symbol and sliding lock facing you.
  2. Epson BrightLink 450Wi Air Filter Replacement: passo 2, immagine 1 di 3 Epson BrightLink 450Wi Air Filter Replacement: passo 2, immagine 2 di 3 Epson BrightLink 450Wi Air Filter Replacement: passo 2, immagine 3 di 3
    • Pull back the sliding lock in the direction away from the projector, and gently open the air filter door while still holding the lock open.
  3. Epson BrightLink 450Wi Air Filter Replacement: passo 3, immagine 1 di 3 Epson BrightLink 450Wi Air Filter Replacement: passo 3, immagine 2 di 3 Epson BrightLink 450Wi Air Filter Replacement: passo 3, immagine 3 di 3
    • Grab the air filter center tab, and pull it gently away from the projector.
    • Replace the filter by slotting in a new filter the same way it was pulled out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 83
