Salta al contenuto principale
Epomaker SK64S Keyboard Switches Replacement
Cosa ti serve
  1. Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: passo 1, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: passo 1, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: passo 1, immagine 3 di 3
    • Do not disassemble keyboard if it is connected to a power source.
    • Unplug the power cable.
  2. Epomaker SK64S Keyboard Switches Replacement: passo 2, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 2, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 2, immagine 3 di 3
    • Align the keycap puller with the keycap.
    • Pull the keycap straight out.
    • Remove all of the keys.
  3. Epomaker SK64S Keyboard Switches Replacement: passo 3, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 3, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 3, immagine 3 di 3
    • Fill the plastic container with water.
    • Add two drops of dish soap.
    • Put in the keycaps.
    • Let the keycaps soak for 30 minutes.
  4. Epomaker SK64S Keyboard Switches Replacement: passo 4, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 4, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 4, immagine 3 di 3
    • Take the keycaps out.
    • Place them on a paper towel.
    • Let the keycaps dry out.
  5. Epomaker SK64S Keyboard Switches Replacement: passo 5, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 5, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 5, immagine 3 di 3
    • Use an alcohol wipe to soak the cotton swab.
    • Clean the board by running the cotton swab along the board.
  6. Epomaker SK64S Keyboard Switches Replacement: passo 6, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 6, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 6, immagine 3 di 3
    • Align the switch puller with the faulty switch.
    • Pull the switch straight out.
  7. Epomaker SK64S Keyboard Switches Replacement: passo 7, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 7, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 7, immagine 3 di 3
    • Align the new key switch.
    • Push the key switch straight down.
  8. Epomaker SK64S Keyboard Switches Replacement: passo 8, immagine 1 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 8, immagine 2 di 3 Epomaker SK64S Keyboard Switches Replacement: passo 8, immagine 3 di 3
    • Align the keycap.
    • Push the keycap straight down.
    • Replace all the keycaps.
Conclusione
Type away!
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 835
