Salta al contenuto principale
Epiphone ES-335 PRO Tuner Replacement
Cosa ti serve
  1. Epiphone ES-335 PRO Tuner Replacement, Strings: passo 1, immagine 1 di 2 Epiphone ES-335 PRO Tuner Replacement, Strings: passo 1, immagine 2 di 2
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
    Chiedi a FixBot
  2. Epiphone ES-335 PRO Tuner Replacement: passo 2, immagine 1 di 1
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
    Chiedi a FixBot
  3. Epiphone ES-335 PRO Tuner Replacement, Tuner: passo 3, immagine 1 di 1
    • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
    • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
    Chiedi a FixBot
  4. Epiphone ES-335 PRO Tuner Replacement: passo 4, immagine 1 di 1
    • The tuner should come right out of the back of the head of the guitar.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 43
Tutti i Tempi: 1,745
