Salta al contenuto principale
Epiphone ES-335 PRO Strings Replacement
  1. Epiphone ES-335 PRO Strings Replacement, Strings: passo 1, immagine 1 di 2 Epiphone ES-335 PRO Strings Replacement, Strings: passo 1, immagine 2 di 2
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
  2. Epiphone ES-335 PRO Strings Replacement: passo 2, immagine 1 di 1
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,189
