Salta al contenuto principale
Entry Door Weatherstripping Replacement
Cosa ti serve
  1. Entry Door Weatherstripping Replacement, Weatherstripping: passo 1, immagine 1 di 2 Entry Door Weatherstripping Replacement, Weatherstripping: passo 1, immagine 2 di 2
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: passo 2, immagine 1 di 3 Entry Door Weatherstripping Replacement: passo 2, immagine 2 di 3 Entry Door Weatherstripping Replacement: passo 2, immagine 3 di 3
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: passo 3, immagine 1 di 1
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: passo 4, immagine 1 di 2 Entry Door Weatherstripping Replacement: passo 4, immagine 2 di 2
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: passo 5, immagine 1 di 2 Entry Door Weatherstripping Replacement: passo 5, immagine 2 di 2
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: passo 6, immagine 1 di 3 Entry Door Weatherstripping Replacement: passo 6, immagine 2 di 3 Entry Door Weatherstripping Replacement: passo 6, immagine 3 di 3
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: passo 7, immagine 1 di 1
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: passo 8, immagine 1 di 2 Entry Door Weatherstripping Replacement: passo 8, immagine 2 di 2
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
Conclusione
Agilakumaran Shanmugalingam
Membro da: 05/10/21
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 147
Tutti i Tempi: 4,891
