Salta al contenuto principale
Enabot EBO SE Wheels Replacement
Cosa ti serve
  1. Enabot EBO SE Wheels Replacement, Wheel Assembly: passo 1, immagine 1 di 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Wheels Replacement: passo 2, immagine 1 di 3 Enabot EBO SE Wheels Replacement: passo 2, immagine 2 di 3 Enabot EBO SE Wheels Replacement: passo 2, immagine 3 di 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Wheels Replacement: passo 3, immagine 1 di 2 Enabot EBO SE Wheels Replacement: passo 3, immagine 2 di 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Wheels Replacement, Wheels: passo 4, immagine 1 di 2 Enabot EBO SE Wheels Replacement, Wheels: passo 4, immagine 2 di 2
    • Pull on the tire tread perpendicularly to the wheels to remove the tread.
    • The wheel should naturally come off with it for replacement.
  5. Enabot EBO SE Wheels Replacement: passo 5, immagine 1 di 2 Enabot EBO SE Wheels Replacement: passo 5, immagine 2 di 2
    • Repeat previous step with the wheels on the other side.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 88
