Salta al contenuto principale
Enabot EBO SE Battery Replacement
Cosa ti serve
  1. Enabot EBO SE Battery Replacement, Wheel Assembly: passo 1, immagine 1 di 1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Battery Replacement: passo 2, immagine 1 di 3 Enabot EBO SE Battery Replacement: passo 2, immagine 2 di 3 Enabot EBO SE Battery Replacement: passo 2, immagine 3 di 3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Battery Replacement: passo 3, immagine 1 di 2 Enabot EBO SE Battery Replacement: passo 3, immagine 2 di 2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Battery Replacement, Lower Housing: passo 4, immagine 1 di 2 Enabot EBO SE Battery Replacement, Lower Housing: passo 4, immagine 2 di 2
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
  5. Enabot EBO SE Battery Replacement: passo 5, immagine 1 di 3 Enabot EBO SE Battery Replacement: passo 5, immagine 2 di 3 Enabot EBO SE Battery Replacement: passo 5, immagine 3 di 3
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
  6. Enabot EBO SE Battery Replacement: passo 6, immagine 1 di 2 Enabot EBO SE Battery Replacement: passo 6, immagine 2 di 2
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
  7. Enabot EBO SE Battery Replacement: passo 7, immagine 1 di 3 Enabot EBO SE Battery Replacement: passo 7, immagine 2 di 3 Enabot EBO SE Battery Replacement: passo 7, immagine 3 di 3
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
  8. Enabot EBO SE Battery Replacement: passo 8, immagine 1 di 3 Enabot EBO SE Battery Replacement: passo 8, immagine 2 di 3 Enabot EBO SE Battery Replacement: passo 8, immagine 3 di 3
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
  9. Enabot EBO SE Battery Replacement, Battery: passo 9, immagine 1 di 3 Enabot EBO SE Battery Replacement, Battery: passo 9, immagine 2 di 3 Enabot EBO SE Battery Replacement, Battery: passo 9, immagine 3 di 3
    • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
    • Flip the tab up and pull the ribbon cable out.
    • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
  10. Enabot EBO SE Battery Replacement: passo 10, immagine 1 di 3 Enabot EBO SE Battery Replacement: passo 10, immagine 2 di 3 Enabot EBO SE Battery Replacement: passo 10, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
  11. Enabot EBO SE Battery Replacement: passo 11, immagine 1 di 2 Enabot EBO SE Battery Replacement: passo 11, immagine 2 di 2
    • Pull the battery casing upwards from the lower half of the assembly to remove it.
  12. Enabot EBO SE Battery Replacement: passo 12, immagine 1 di 2 Enabot EBO SE Battery Replacement: passo 12, immagine 2 di 2
    • Carefully remove the battery from the casing in order to replace.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 63
Tutti i Tempi: 134
