Salta al contenuto principale
Ematic eGlide 4 Side Button Array Replacement
Cosa ti serve
  1. Ematic eGlide 4 Side Button Array Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Side Button Array Replacement: passo 2, immagine 1 di 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Side Button Array Replacement: passo 3, immagine 1 di 2 Ematic eGlide 4 Side Button Array Replacement: passo 3, immagine 2 di 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Side Button Array Replacement, Side Button Array: passo 4, immagine 1 di 1
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Side Button Array Replacement: passo 5, immagine 1 di 2 Ematic eGlide 4 Side Button Array Replacement: passo 5, immagine 2 di 2
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Side Button Array Replacement: passo 6, immagine 1 di 1
    • Remove the side button array from the device.
Conclusione
Baylor, Team 5-8, Williams Spring 2015 Membro di Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 185
