Salta al contenuto principale
Ematic Genesis 2 Screen Replacement
Cosa ti serve
  1. Ematic Genesis 2 Screen Replacement, Screen: passo 1, immagine 1 di 2 Ematic Genesis 2 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: passo 2, immagine 1 di 3 Ematic Genesis 2 Screen Replacement: passo 2, immagine 2 di 3 Ematic Genesis 2 Screen Replacement: passo 2, immagine 3 di 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: passo 3, immagine 1 di 2 Ematic Genesis 2 Screen Replacement: passo 3, immagine 2 di 2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: passo 4, immagine 1 di 1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 442
