Salta al contenuto principale
Ematic Genesis 2 Charging Port Replacement
Cosa ti serve
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 2 Ematic Genesis 2 Charging Port Replacement, Charging Port: passo 1, immagine 2 di 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: passo 2, immagine 1 di 3 Ematic Genesis 2 Charging Port Replacement: passo 2, immagine 2 di 3 Ematic Genesis 2 Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: passo 3, immagine 1 di 2 Ematic Genesis 2 Charging Port Replacement: passo 3, immagine 2 di 2
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: passo 4, immagine 1 di 2 Ematic Genesis 2 Charging Port Replacement: passo 4, immagine 2 di 2
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: passo 5, immagine 1 di 2 Ematic Genesis 2 Charging Port Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: passo 6, immagine 1 di 1
    • Solder replacement port into place.
    • Make sure all connections match original.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 543
