Salta al contenuto principale
Ematic Genesis 2 Battery Replacement
Cosa ti serve
  1. Ematic Genesis 2 Battery Replacement, Battery: passo 1, immagine 1 di 2 Ematic Genesis 2 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: passo 2, immagine 1 di 3 Ematic Genesis 2 Battery Replacement: passo 2, immagine 2 di 3 Ematic Genesis 2 Battery Replacement: passo 2, immagine 3 di 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: passo 4, immagine 1 di 1
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 348
