Salta al contenuto principale
Ematic Funtab FTABXXX Speaker Replacement
Cosa ti serve
  1. Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: passo 1, immagine 1 di 2 Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: passo 1, immagine 2 di 2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Speaker Replacement, Locating the speaker: passo 2, immagine 1 di 1
    • Locate the speaker in the bottom right hand side of the device. Note the red and black wires attaching the speaker to the motherboard.
  3. Ematic Funtab FTABXXX Speaker Replacement, Removing the old speaker: passo 3, immagine 1 di 1
    • Carefully remove the soldered wires from the motherboard. Note the positive and negative symbol where the red and black wires are soldered to on the motherboard.
  4. Ematic Funtab FTABXXX Speaker Replacement, Soldering the new speaker: passo 4, immagine 1 di 1
    • Carefully, solder the new speaker wires to the motherboard in the same fashion as the old speaker. The red wire to the '+' symbol and the black wire to the '-' symbol.
  5. Ematic Funtab FTABXXX Speaker Replacement, Positioning the speaker: passo 5, immagine 1 di 1
    • Once the solder points have cooled, position the speaker into the speaker housing on the back bezel as shown in the image.
Conclusione
USF Tampa, Team 6-3, Brown Winter 2015 Membro di USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 166
