Salta al contenuto principale
Ematic Funtab FTABXXX Power and Sound Buttons Replacement
Cosa ti serve
  1. Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: passo 1, immagine 1 di 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: passo 1, immagine 2 di 2
    • Before opening the device make sure the device is powered down if possible.
    • Using a spading tool open the device along the clips.
  2. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: passo 2, immagine 1 di 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: passo 2, immagine 2 di 2
    • Locate the plastic power button.
    • Locate the plastic sound button.
  3. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: passo 3, immagine 1 di 1
    • Once the power button has been located place it in the appropriate spot as indicated by the picture. Make sure that the plastic button will connect with the black button when pressed.
  4. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: passo 4, immagine 1 di 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: passo 4, immagine 2 di 2
    • Once the sound button has been located place it in the correct spot as indicated by the picture.
    • Make sure the plastic sound button will connect with the small black buttons when pressed down.
Conclusione
Xavier Smith
Membro da: 01/21/15
210 Reputazione
2 Guide realizzate
USF Tampa, Team 6-3, Brown Winter 2015 Membro di USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 312
