Salta al contenuto principale
Ematic FunTab 3 Touch Screen Replacement
Cosa ti serve
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: passo 1, immagine 1 di 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: passo 1, immagine 2 di 3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: passo 1, immagine 3 di 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Touch Screen Replacement: passo 2, immagine 1 di 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: passo 3, immagine 1 di 1
    • Remove the black tape to reveal the screen connector.
  4. Ematic FunTab 3 Touch Screen Replacement: passo 4, immagine 1 di 2 Ematic FunTab 3 Touch Screen Replacement: passo 4, immagine 2 di 2
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
  5. Ematic FunTab 3 Touch Screen Replacement: passo 5, immagine 1 di 2 Ematic FunTab 3 Touch Screen Replacement: passo 5, immagine 2 di 2
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
  6. Ematic FunTab 3 Touch Screen Replacement: passo 6, immagine 1 di 1
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: passo 7, immagine 1 di 2 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: passo 7, immagine 2 di 2
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
  8. Ematic FunTab 3 Touch Screen Replacement: passo 8, immagine 1 di 1
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
Conclusione
Amanda Davis
Membro da: 07/11/18
581 Reputazione
5 Guide realizzate
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membri
12 Guide realizzate
1Commento della guida
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,025
