Salta al contenuto principale
Ematic FunTab 3 Camera Replacement
Cosa ti serve
  1. Ematic FunTab 3 Camera Replacement, Back Panel: passo 1, immagine 1 di 3 Ematic FunTab 3 Camera Replacement, Back Panel: passo 1, immagine 2 di 3 Ematic FunTab 3 Camera Replacement, Back Panel: passo 1, immagine 3 di 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: passo 2, immagine 1 di 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: passo 3, immagine 1 di 2 Ematic FunTab 3 Camera Replacement, Camera: passo 3, immagine 2 di 2
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: passo 5, immagine 1 di 2 Ematic FunTab 3 Camera Replacement: passo 5, immagine 2 di 2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Conclusione
Amanda Davis
Membro da: 07/11/18
581 Reputazione
5 Guide realizzate
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 233
