Salta al contenuto principale
Ematic FunTab 3 Back Panel Replacement
Cosa ti serve
  1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, immagine 1 di 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, immagine 2 di 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, immagine 3 di 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Back Panel  Replacement: passo 2, immagine 1 di 1
    • Pull the back panel away from the screen.
Conclusione
Harrison Lee
Membro da: 07/12/18
85 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membri
12 Guide realizzate
Un commento
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 196
