Salta al contenuto principale
Eluktronics N850HK SSD Replacement
Cosa ti serve
  1. Eluktronics N850HK SSD Replacement, SSD: passo 1, immagine 1 di 3 Eluktronics N850HK SSD Replacement, SSD: passo 1, immagine 2 di 3 Eluktronics N850HK SSD Replacement, SSD: passo 1, immagine 3 di 3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: passo 2, immagine 1 di 2 Eluktronics N850HK SSD Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: passo 3, immagine 1 di 2 Eluktronics N850HK SSD Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: passo 4, immagine 1 di 2 Eluktronics N850HK SSD Replacement: passo 4, immagine 2 di 2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: passo 5, immagine 1 di 3 Eluktronics N850HK SSD Replacement: passo 5, immagine 2 di 3 Eluktronics N850HK SSD Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: passo 6, immagine 1 di 3 Eluktronics N850HK SSD Replacement: passo 6, immagine 2 di 3 Eluktronics N850HK SSD Replacement: passo 6, immagine 3 di 3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: passo 7, immagine 1 di 3 Eluktronics N850HK SSD Replacement: passo 7, immagine 2 di 3 Eluktronics N850HK SSD Replacement: passo 7, immagine 3 di 3
    • Reassemble by following the directions in reverse order.
Conclusione
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 347
Tutti i Tempi: 4,284
