Introduzione
Nothing is more disappointing than building a radio just to find that it refuses to catch any signal in the FM world. I have come to find that this can occur in the Elenco model when the capacitor, C-22, is either broken or disconnected. This guide should be adequate in showing you how to remove and replace the capacitor.
  • Remove the battery and the antenna.
  • Pre-heat the soldering iron.
Aggiungi Commento
  • Place hot solder iron on thermal pad, capacitor lead, and the mound of solder until solder liquefies.
  • Apply desoldering pump to remove the solder from the circuit board.
  • Repeat the instructions to remove solder from the adjacent solder mound.
Aggiungi Commento
  • Gently remove the capacitor by pulling the two leads out of the circuit board.
Aggiungi Commento
  • Place the leads of the capacitor through designated holes of the circuit board.
  • Place solder iron on the thermal pad and the lead.
  • Once this is done wait a few seconds until both items heat up.
  • Once they are heated, apply the solder to the other side so that the solder iron and the solder are not directly touching.
  • Wait 3 to 5 seconds or until enough solder covers the whole pad and forms a nice mound.
  • Remove the solder, leaving the solder iron on the pad for 2 to three seconds, then remove the solder iron.
  • Repeat for the other lead.
Aggiungi Commento
  • Plug the battery in and attach the antenna to test the radio.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Charles Riel
Membro da: 10/10/2014
191 Reputazione
1 Guida realizzata
Charlie Riel Membro di Charlie Riel
Community
1 Membro
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 701
