Salta al contenuto principale
Element GC-1020 Screen Replacement
Cosa ti serve
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: passo 1, immagine 1 di 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Screen  Replacement: passo 2, immagine 1 di 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Screen  Replacement, Screen: passo 3, immagine 1 di 1
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
  4. Element GC-1020 Screen  Replacement: passo 4, immagine 1 di 2 Element GC-1020 Screen  Replacement: passo 4, immagine 2 di 2
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
  5. Element GC-1020 Screen  Replacement: passo 5, immagine 1 di 3 Element GC-1020 Screen  Replacement: passo 5, immagine 2 di 3 Element GC-1020 Screen  Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
  6. Element GC-1020 Screen  Replacement: passo 6, immagine 1 di 3 Element GC-1020 Screen  Replacement: passo 6, immagine 2 di 3 Element GC-1020 Screen  Replacement: passo 6, immagine 3 di 3
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 392
