Salta al contenuto principale
Elegoo Mars 3 Motherboard Replacement
Cosa ti serve
  1. Elegoo Mars 3 Motherboard Replacement, Remove the back screws: passo 1, immagine 1 di 1
    • Remove 6 screws.
    • 12.5mm self tapping screws with 2.0mm hex socket head
  2. Elegoo Mars 3 Motherboard Replacement, Remove the back lid: passo 2, immagine 1 di 2 Elegoo Mars 3 Motherboard Replacement, Remove the back lid: passo 2, immagine 2 di 2
    • Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
    • The back of the lid has a PCB with cables connecting it to the motherboard inside the unit. While not particularly fragile, do take care so you do not damage the connectors.
  3. Elegoo Mars 3 Motherboard Replacement, Remove the LED and power connectors: passo 3, immagine 1 di 2 Elegoo Mars 3 Motherboard Replacement, Remove the LED and power connectors: passo 3, immagine 2 di 2
    • Remove the connectors by pulling them straight out.
    • Make sure you connect the connectors in the correct sockets during reassembly!
  4. Elegoo Mars 3 Motherboard Replacement, Remove the resin panel connector: passo 4, immagine 1 di 3 Elegoo Mars 3 Motherboard Replacement, Remove the resin panel connector: passo 4, immagine 2 di 3 Elegoo Mars 3 Motherboard Replacement, Remove the resin panel connector: passo 4, immagine 3 di 3
    • Use a spudger or similar tool (your finger nail works if you can get it there) to loosen the resin panel connector by flipping the dark gray part 90° down.
    • Pull the cable straight up.
    • Be careful not to bend the cable!
  5. Elegoo Mars 3 Motherboard Replacement, Remove the bottom right connectors: passo 5, immagine 1 di 1
    • Remove the three cable connectors in the bottom right corner by pulling them straight out.
    • Be sure to pull the connectors, and not the cables!
    • If you are also replacing the limit switch, now is a good time to do so.
  6. Elegoo Mars 3 Motherboard Replacement, Unfasten the motherboard: passo 6, immagine 1 di 1
    • Remove the two screws fastening the motherboard to the unit.
    • 7.5mm self tapping screws with 2.0mm hex socket head
    • The touch screen cable on the right and the USB cable on the left are still connected to the motherboard.
  7. Elegoo Mars 3 Motherboard Replacement, Remove the tape covering the touch screen connector: passo 7, immagine 1 di 2 Elegoo Mars 3 Motherboard Replacement, Remove the tape covering the touch screen connector: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers to get a grip on and remove the tape covering the touch screen connector.
    • You can transfer this tape and reuse it on the new motherboard.
  8. Elegoo Mars 3 Motherboard Replacement, Remove the touch screen cable: passo 8, immagine 1 di 3 Elegoo Mars 3 Motherboard Replacement, Remove the touch screen cable: passo 8, immagine 2 di 3 Elegoo Mars 3 Motherboard Replacement, Remove the touch screen cable: passo 8, immagine 3 di 3
    • Use a spudger or similar to unlock the connector by pushing the dark gray part to the right, away from the connector, both on the top and bottom.
    • Note how far into the connector the cable is seated. When reinserting the cable in the new motherboard it can be hard to feel if the cable is fully inserted.
    • Remove the cable by pulling it out of the connector to the right.
  9. Elegoo Mars 3 Motherboard Replacement, Remove the USB cable: passo 9, immagine 1 di 1
    • Unplug the USB cable.
    • In my case the glue did not stick to the USB cable, just the USB socket on the motherboard, so I was able to just pull it out without doing anything with the glue. If necessary you should be able to pry off the glue blob with a spudger or similar.
    • During reassembly it is not necessary to glue these together.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 49
Tutti i Tempi: 1,731
