Salta al contenuto principale
Electrohome EAAC475 USB Port Replacement
Cosa ti serve
  1. Electrohome EAAC475 USB Port Replacement, Battery: passo 1, immagine 1 di 2 Electrohome EAAC475 USB Port Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 USB Port Replacement: passo 2, immagine 1 di 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 USB Port Replacement, Buttons: passo 3, immagine 1 di 2 Electrohome EAAC475 USB Port Replacement, Buttons: passo 3, immagine 2 di 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 USB Port Replacement: passo 4, immagine 1 di 3 Electrohome EAAC475 USB Port Replacement: passo 4, immagine 2 di 3 Electrohome EAAC475 USB Port Replacement: passo 4, immagine 3 di 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 USB Port Replacement: passo 5, immagine 1 di 2 Electrohome EAAC475 USB Port Replacement: passo 5, immagine 2 di 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 USB Port Replacement, USB Port: passo 6, immagine 1 di 1
    • Locate the screw holding the USB circuit board in place.
    • Take a Philips head screwdriver and remove the 10 mm screw.
  7. Electrohome EAAC475 USB Port Replacement: passo 7, immagine 1 di 1
    • Upon removing the screw, the circuit board should slide right out to look like this.
    • The USB port is to the right in this picture.
  8. Electrohome EAAC475 USB Port Replacement: passo 8, immagine 1 di 1
    • Find the pins of the USB port that are soldered into the circuit board.
    • Compare the new port with the old port to be sure which pins to work with.
    • Take the soldering gun and heat up the pins one at a time.
    • If you are not familiar with soldering, consult a more skilled individual or at least a how-to guide.
    • Use solder wick with each pin to remove the solder.
    • Remove the USB port.
Conclusione
IUPUI, Team 2-1, Harley Spring 2016 Membro di IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 267
