Salta al contenuto principale
Electrohome EAAC475 Speaker Replacement
Cosa ti serve
  1. Electrohome EAAC475 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Electrohome EAAC475 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: passo 3, immagine 1 di 2 Electrohome EAAC475 Speaker Replacement, Buttons: passo 3, immagine 2 di 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: passo 4, immagine 1 di 3 Electrohome EAAC475 Speaker Replacement: passo 4, immagine 2 di 3 Electrohome EAAC475 Speaker Replacement: passo 4, immagine 3 di 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: passo 5, immagine 1 di 2 Electrohome EAAC475 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Electrohome EAAC475 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: passo 7, immagine 1 di 1
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: passo 8, immagine 1 di 1
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: passo 9, immagine 1 di 1
    • Detach the wires on the speaker and replace them with new ones.
Conclusione
Ruolin Cai
Membro da: 02/16/16
273 Reputazione
2 Guide realizzate
IUPUI, Team 2-1, Harley Spring 2016 Membro di IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 388
