Salta al contenuto principale
Electrohome EAAC475 Projector Lens Replacement
Cosa ti serve
  1. Electrohome EAAC475 Projector Lens Replacement, Battery: passo 1, immagine 1 di 2 Electrohome EAAC475 Projector Lens Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Projector Lens Replacement: passo 2, immagine 1 di 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: passo 3, immagine 1 di 1
    • Slowly and carefully move one side away from another without detaching anything on the device.
  4. Electrohome EAAC475 Projector Lens Replacement: passo 4, immagine 1 di 1
    • Detach the projector.
  5. Electrohome EAAC475 Projector Lens Replacement: passo 5, immagine 1 di 2 Electrohome EAAC475 Projector Lens Replacement: passo 5, immagine 2 di 2
    • Unplug the projector's connector from the circuit board.
  6. Electrohome EAAC475 Projector Lens Replacement: passo 6, immagine 1 di 1
    • Take off the rubber ring.
  7. Electrohome EAAC475 Projector Lens Replacement: passo 7, immagine 1 di 3 Electrohome EAAC475 Projector Lens Replacement: passo 7, immagine 2 di 3 Electrohome EAAC475 Projector Lens Replacement: passo 7, immagine 3 di 3
    • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
    • Slide the tool along the crease to separate.
  8. Electrohome EAAC475 Projector Lens Replacement: passo 8, immagine 1 di 1
    • Take the lens out of the projector.
  9. Electrohome EAAC475 Projector Lens Replacement: passo 9, immagine 1 di 1
    • Separate the lens and the gear by unscrewing the gear.
Conclusione
IUPUI, Team 2-1, Harley Spring 2016 Membro di IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 351
