Salta al contenuto principale
Electrohome EAAC475 Display Replacement
Cosa ti serve
  1. Electrohome EAAC475 Display Replacement, Battery: passo 1, immagine 1 di 2 Electrohome EAAC475 Display Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Display Replacement: passo 2, immagine 1 di 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Display Replacement, Buttons: passo 3, immagine 1 di 2 Electrohome EAAC475 Display Replacement, Buttons: passo 3, immagine 2 di 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Display Replacement: passo 4, immagine 1 di 3 Electrohome EAAC475 Display Replacement: passo 4, immagine 2 di 3 Electrohome EAAC475 Display Replacement: passo 4, immagine 3 di 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Display Replacement: passo 5, immagine 1 di 2 Electrohome EAAC475 Display Replacement: passo 5, immagine 2 di 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Display Replacement, Display: passo 6, immagine 1 di 2 Electrohome EAAC475 Display Replacement, Display: passo 6, immagine 2 di 2
    • Remove the two 8 mm Phillips screws supporting the circuit board.
    • Pull off the circuit board to access the panels below.
  7. Electrohome EAAC475 Display Replacement: passo 7, immagine 1 di 2 Electrohome EAAC475 Display Replacement: passo 7, immagine 2 di 2
    • Remove the two 6 mm Phillips screws supporting the mini circuit board for the frontal buttons.
    • Remove the mini circuit board.
  8. Electrohome EAAC475 Display Replacement: passo 8, immagine 1 di 2 Electrohome EAAC475 Display Replacement: passo 8, immagine 2 di 2
    • Move the now free circuit boards away from the display.
    • Remove the final two 7 mm Phillips screws securing the display.
    • Pull the display screen away from the casing.
  9. Electrohome EAAC475 Display Replacement: passo 9, immagine 1 di 1
    • You have successfully accessed the display.
    • Replacing the display with a new one will be challenging as soldering and connecting micro wires are necessary.
Conclusione
IUPUI, Team 2-1, Harley Spring 2016 Membro di IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 726
