Salta al contenuto principale
Electrical Wall Outlet Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Electrical Wall Outlet Replacement, Wall Outlet: passo 1, immagine 1 di 2 Electrical Wall Outlet Replacement, Wall Outlet: passo 1, immagine 2 di 2
    • Turn off electrical power from the breaker by switching off the breaker that is connected to the designated area.
    • Check power by plugging in rechargeable device and check if charging. If not charging, power to the wall is off.
  2. Electrical Wall Outlet Replacement: passo 2, immagine 1 di 1
    • Remove the screw from the outlet plate using a flathead screwdriver.
  3. Electrical Wall Outlet Replacement: passo 3, immagine 1 di 1
    • Remove plate from outlet using a Phillips screwdriver.
  4. Electrical Wall Outlet Replacement: passo 4, immagine 1 di 1
    • Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
  5. Electrical Wall Outlet Replacement: passo 5, immagine 1 di 1
    • Remove wires from outlet by gently pulling them out of the outlet and wall.
  6. Electrical Wall Outlet Replacement: passo 6, immagine 1 di 2 Electrical Wall Outlet Replacement: passo 6, immagine 2 di 2
    • Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
    • Insert wire into the designated port and tighten with Phillips Screwdriver.
    • Neutral Wire- White
    • Ground Wire- Copper
    • Hot Wire- Black
  7. Electrical Wall Outlet Replacement: passo 7, immagine 1 di 3 Electrical Wall Outlet Replacement: passo 7, immagine 2 di 3 Electrical Wall Outlet Replacement: passo 7, immagine 3 di 3
    • Reassemble the outlet as it was removed.
Conclusione
Altre 5 persone hanno completato questa guida.
Texas Tech, Team 22-4, Rauch Spring 2016 Membro di Texas Tech, Team 22-4, Rauch Spring 2016
TTU-RAUCH-S16S22G4
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,209
