Salta al contenuto principale
Electric Wheelchair Battery Replacement
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, immagine 1 di 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, immagine 2 di 3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, immagine 3 di 3
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: passo 2, immagine 1 di 2 Electric Wheelchair Battery Replacement: passo 2, immagine 2 di 2
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: passo 3, immagine 1 di 2 Electric Wheelchair Battery Replacement: passo 3, immagine 2 di 2
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: passo 4, immagine 1 di 2 Electric Wheelchair Battery Replacement: passo 4, immagine 2 di 2
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: passo 5, immagine 1 di 3 Electric Wheelchair Battery Replacement: passo 5, immagine 2 di 3 Electric Wheelchair Battery Replacement: passo 5, immagine 3 di 3
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: passo 6, immagine 1 di 3 Electric Wheelchair Battery Replacement: passo 6, immagine 2 di 3 Electric Wheelchair Battery Replacement: passo 6, immagine 3 di 3
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: passo 7, immagine 1 di 1
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: passo 8, immagine 1 di 3 Electric Wheelchair Battery Replacement: passo 8, immagine 2 di 3 Electric Wheelchair Battery Replacement: passo 8, immagine 3 di 3
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: passo 9, immagine 1 di 3 Electric Wheelchair Battery Replacement: passo 9, immagine 2 di 3 Electric Wheelchair Battery Replacement: passo 9, immagine 3 di 3
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 6,805
