Salta al contenuto principale
Electric Stove Burners and Drip Pans Replacement
Cosa ti serve
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: passo 1, immagine 1 di 1
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: passo 2, immagine 1 di 3 Electric Stove Burners and Drip Pans Replacement: passo 2, immagine 2 di 3 Electric Stove Burners and Drip Pans Replacement: passo 2, immagine 3 di 3
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: passo 3, immagine 1 di 1
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: passo 4, immagine 1 di 2 Electric Stove Burners and Drip Pans Replacement: passo 4, immagine 2 di 2
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: passo 5, immagine 1 di 2 Electric Stove Burners and Drip Pans Replacement: passo 5, immagine 2 di 2
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: passo 6, immagine 1 di 1
    • Slide new burner through the receptacle.
    • Reassemble stove after.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 111
Tutti i Tempi: 4,210
