Salta al contenuto principale
Electric Outlet Cover Replacement
Cosa ti serve
  1. Electric Outlet Cover Replacement, Cover: passo 1, immagine 1 di 1
    • Setup a workspace around the damaged/old electrical outlet cover you are replacing.
  2. Electric Outlet Cover Replacement: passo 2, immagine 1 di 2 Electric Outlet Cover Replacement: passo 2, immagine 2 di 2
    • Use the flathead screwdriver to remove the screw from the outlet.
    • Lefty loose-y righty tight-y.
  3. Electric Outlet Cover Replacement: passo 3, immagine 1 di 3 Electric Outlet Cover Replacement: passo 3, immagine 2 di 3 Electric Outlet Cover Replacement: passo 3, immagine 3 di 3
    • Remove the faceplate off of the wall.
  4. Electric Outlet Cover Replacement: passo 4, immagine 1 di 1
    • Now that the faceplate is removed clean up the interior and surrounding area of the outlet.
    • Be cautious as you clean the exposed outlet due to the electric current still running through it.
Conclusione
To make sure the outlet cover is properly installed, try to move the faceplate around and plug in your devices to ensure the outlet still works
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 297
Tutti i Tempi: 7,436
