Salta al contenuto principale
Edwin the Duck Motherboard Replacement
Cosa ti serve
  1. Edwin the Duck Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Edwin the Duck Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: passo 2, immagine 1 di 2 Edwin the Duck Motherboard Replacement: passo 2, immagine 2 di 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: passo 3, immagine 1 di 1
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: passo 4, immagine 1 di 2 Edwin the Duck Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: passo 5, immagine 1 di 2 Edwin the Duck Motherboard Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: passo 6, immagine 1 di 1
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
Conclusione
Caleb Kim
Membro da: 10/18/17
143 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G4, Rose Fall 2017 Membro di UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 404
