Salta al contenuto principale
Ecovacs DEEBOT D35 Vacuum Motor Replacement
Cosa ti serve
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: passo 1, immagine 1 di 1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 2, immagine 1 di 1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 3, immagine 1 di 1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 4, immagine 1 di 1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 5, immagine 1 di 1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 6, immagine 1 di 1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 7, immagine 1 di 1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 8, immagine 1 di 1
    • Remove the vacuum motor body
Conclusione
Altre 3 persone hanno completato questa guida.
Brian
Membro da: 02/15/17
475 Reputazione
3 Guide realizzate
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro di USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Membri
4 Guide realizzate
Un commento
thanks a lots for the valuable info
sk law - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 8,961
