Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The spinning brushes are located on the backside of the DEEBOT D35 on the front right and left edge. These brushes pull dirt to the vacuum where it is suctioned up.
Parti
  1. Roll the Deebot over on a flat surface. The brushes will be located on the front with bright yellow connectors.
    • Roll the Deebot over on a flat surface. The brushes will be located on the front with bright yellow connectors.
  2. Place a plastic opening tool under the lip of the brush head.
    • Place a plastic opening tool under the lip of the brush head.
  3. Gently pry up with the opening tool so that the brush comes out completely.
    • Gently pry up with the opening tool so that the brush comes out completely.
Conclusione
Brian
Membro da: 15/02/2017
454 Reputazione
3 Guide realizzate
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro di USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 51
Tutti i Tempi: 1,941
