Salta al contenuto principale
Ecovacs DEEBOT D35 Motherboard Replacement
Cosa ti serve
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: passo 4, immagine 1 di 1
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: passo 5, immagine 1 di 2 Ecovacs DEEBOT D35 Motherboard Replacement: passo 5, immagine 2 di 2
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, immagine 1 di 3 Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, immagine 2 di 3 Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, immagine 3 di 3
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: passo 8, immagine 1 di 2 Ecovacs DEEBOT D35 Motherboard Replacement: passo 8, immagine 2 di 2
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: passo 9, immagine 1 di 1
    • Carefully disconnect the motherboard from the Deebot body.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro di USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,739
