Salta al contenuto principale
Ecovacs DEEBOT D35 Battery Replacement
Cosa ti serve
  1. Ecovacs DEEBOT D35 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Press and hold the tabs on both sides of the battery.
  2. Ecovacs DEEBOT D35 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the Deebot
  3. Ecovacs DEEBOT D35 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the screw attaching the battery housing.
  4. Ecovacs DEEBOT D35 Battery Replacement: passo 4, immagine 1 di 1
    • Inert the new battery casing into the housing.
    • Replace the screw attaching the housing.
    • Replace the batter housing in the Deebot.
Conclusione
Altre 3 persone hanno completato questa guida.
Brian
Membro da: 02/15/17
475 Reputazione
3 Guide realizzate
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro di USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 Membri
4 Guide realizzate
7 Commenti
How do you actually take the battery pack out of the casing?
Jonathan A - Replica
Where can i find a replacement battery for deebot model d35
Travis neas - Replica
JonathanA - you don't, it comes complete in the casing and can not be opened.
Kate Oe - Replica
But where can we buy a replacement battery for deebot 35?
Kay Pott - Replica
Where can i buy a replacement battery for D35
Terry Martin
Terry Martin -
where can you buy battery for d35
glynn wild - Replica
I cannot get the battery separated from its joint to insert the replacement battery on my n79s. My fingers are raw from squeezing and pulling.
Nem - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 47
Tutti i Tempi: 13,938
