Salta al contenuto principale
Eco X Gear LED Display Replacement
Cosa ti serve
  1. Eco X Gear LED Display Replacement, Frame: passo 1, immagine 1 di 1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: passo 2, immagine 1 di 1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: passo 3, immagine 1 di 1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: passo 4, immagine 1 di 1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: passo 5, immagine 1 di 1
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: passo 6, immagine 1 di 1
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 137
